So after poweron, engine keeps running and with the toner and cover removed, i can see the toner-feed-gear spinning, every few seconds. But the display say;s "add toner". The developer tried in another 3820, was printing fine, spotless. Also swapped the drum and high voltage pcb, from the working machine, checked the cables, still the same error.
Whats wrong here? Engine controller?
