TAS-300CI Error C-1400 jam-00
  • rashid120
    • Jun 2010
    • 76
    [Error Code] TAS-300CI Error C-1400 jam-00
    i encountered a problem in TAS-300CI error C-1400 at machine start up.if we reset by U-906 Showing jam-00 any Idea? already checked the rotary motor and Sensor working OK.
  • copygirl
    • 75
    Re: TAS-300CI Error C-1400 jam-00
    Did you try putting it in simulation to see which switch you are having trouble with. It may lead you right to it. I know on the 420i there was a problem with the middle conveying section not being seated all the way in and causing a J00. Did you check the conveying unit right over the cassette? I'd try simulation first. Good luck.
    Ginger
    • Tonerkiller
      • Oct 2012
      • 668
      It is the unit above the fuser. I think there was a bulletin on that code j00 j51 and j50. That sensoe is flaged that is why you have a j00 (jam at power up)
      • rashid120
        • Jun 2010
        • 76
        Friends....its is solved by replacing main front PCB assembly.rotary motor is getting 24v from this PCB and i found burned IC on the PCB.
        Thanks for your assistance.
