Kyocera KM1820 Scan?
  • blackdog
    • Jun 2012
    • 211
    Just installed this box, downloaded print and scan (twain) drivers, print works fine can't get scan program? Customer wants to scan to desktop. I see a KM1820 in control panel (scanners). Using USB, desktop op is Vista. I have no OEM CD. There is no fax option installed on KM1820. What am I missing other than a brain. Thanks
  • kkendric
    • 301
    Re: Kyocera KM1820 Scan?
    I could be wrong, but I thought that the 1820 was set up to network scan only.
    • blackdog
      • Jun 2012
      • 211
      Thanks kkendric, are you suggesting using the network card rather than USB? If this is the case will I get a scanner program once this done? Are there any other utilities I need to download?
      • jewen25
        • Mar 2009
        • 197
        DOWNLOAD XNVIEW its a free software that you can use a scanner utilities
        ERROR HELP ME AND HELP YOU
        • Zackuth
          • Aug 2009
          • 448
          We have had issues setting up scanning to a computer using Vista and above.
          If at first you don't succeed, redefine success
          • blackdog
            • Jun 2012
            • 211
            Hey thanks guys, I'll try that free utilities download & Zackuth I tried to reply to your tread "Toshiba Parts" but post wouldn't let me. Anyway if you have parts #'s talk to a sales rep @ PR and they will get you any part you might need.
            • ccwilliams3
              • Jun 2009
              • 22
              You can scan with SMB you just have to make sure and have a username and password to log into the PC and you have to put that same user name and password in for every time the user wants to scan something to the computer.
