Kyocera FS-C2126MFP Command Center Password Reset
  • pudl
    • Jun 2025
    [Misc] Kyocera FS-C2126MFP Command Center Password Reset
    I have changed the Kyocera Command Center password on an FS-C2126MFP and forgotten it.
    Is there a way to reset the password or reset the whole machine to factory defaults?
    I can still access everything if I switch User Login from Off to Local Authentication and use an administrator account. However, I would still like to reset the password for User Login -> Off mode just in case I decide to sell it.
    I have tried these Prescribe commands:
    ACNT 'REST' - Returns an Account error 07 on printer's LCD.
    EGRE - Does not seem to do anything.
    SIOP0, 'RESET:0' - Does not seem to do anything.
    Regards
    pudl
  • DWise
    • 895
    Re: Kyocera FS-C2126MFP Command Center Password Reset
    Regards
    pudl
    I would try executing a U020 and/or U021. If those don't work, you may need to replace a PWB.
    Do for one what you wished you could do for everyone. - Andy Stanley
    • pudl
      Sooo... five years later I came up with a solution. I did a 'Reset to factory defaults' and the password was back to admin00.
      • Don N.
        • Nov 2011
        • 409
        Was that via the service/simulation mode? 20/21? If not, what menu/where is it? I don't mind losing all the network settings, etc...
        • pudl
          I did it from the web interface. The functionality was under Basic -> Reset.
