This one is the second dead one on me this week. Is there a bulletin on these machines just going dead. Thx
fs1035
Re: fs1035
I'm not aware of a bulletin regarding these machines "going dead".
Have you been able to diagnose what the issue is? Were both printers in the same building? Same room?
We have seen the Main PWB being the issue on power-related problems on several FS1135MFP's, which would likely be a problem on FS1035MFP as well.Do for one what you wished you could do for everyone. - Andy Stanley -
Re: fs1035
Machines are in two different locations. 1st one was the main. I'm leaning to main again here that's why I'm curious of a bulletinComment
Re: fs1035
Our machine clicks once when the power button is pushed, and does nothing, no lights, sounds or activity.
Any info will be appreciated!Comment
Re: fs1035
FS1028,1128, 1035 & 1135, all have 24 volts supplied to the main board, small power units on the main board regulate it to the voltage the board needs, 3.3 volts 1.8 volts etc. There are some IC's in these circuits that have been known to fail. So your power supply is probably good and your main board is possibly defective.Comment
