Has any one see these jam codes yet. One of my guyes was working on it. He said that the paper just stops.I am going out there today.
FS-6530 j9200 and j9410
Tags: None
Re: FS-6530 j9200 and j9410
Our is a brand new install and not good, and so far have not had the ability to try these measures on DP.
Our problem extends to cassette number 1 not feeding correctly either. Any other experiences? -
He did not tell me the whole story. It ended up being that he had a sensor unplugged. I did cl the tires and clutch while i was troubleshooting the issue. It has been working fine since then.Comment
hai...open the top cover and run sim203 with paper at normal speed.....check the two photo interrupters and its actuators ...some time the actuator will not move properly,to close the interrupter... may be its staying in one position or not enough to close the interrupter....Comment
