SCAN OCR
  • Jamil Mungur
    • Feb 2013
    • 34
    SCAN OCR
    Hello
    Can someone explain to me how to use OCR functionality on Kyocera Copiers ?
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: SCAN OCR
    go to Kyocera's site and look at the HyPASS apps for best descriptions
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • daveyball
      • May 2009
      • 314
      Re: SCAN OCR
      Originally posted by Jamil Mungur
      Hello
      As far as I know all the function does is to scan the docs to optimise them for OCR software it doesn't do the OCR if that what you think
      • spandx17
        • Mar 2010
        • 30
        Re: SCAN OCR
        You would need a workflow setup using the DMS Link Hypass App to be able to OCR documents when scanning.
        • RollingROARANDA
          • Nov 2012
          • 72
          Re: SCAN OCR
          Yes and Im the guy who can set it up and sell it to ya! *wink*
          I suggest try DMS Link, then decide if it's for you.. Remember, OCR isn't perfect at all times. It's good to see if you like it first.
