TA 6500i Blank screen when power is switched on.
  • brancas
    • Jul 2009
    • 80
    changed control panel problem still exists. checked main pcb no power to fan network board and hard drive . need to verify if main pwb is the issue any ideas suggestons?
  • redzventures
    Service Tech
    • May 2009
    • 45
    Have you updated the firmware?
    Sounds a little minor but with any strange error like this the first thing to try would be a firmware upgrade. The screen may be blank but if you used a USB with an activity light you would know that it has been recognised. Worth trying for the time it takes to do. Leave the machine for 30 minutes to make sure it had a good chance of upgrading and then power off/on.
    Good luck.
    • brancas
      • Jul 2009
      • 80
      Re: Have you updated the firmware?
      Good luck.
      tried updating firmware no activity light from usb also reset connections on main PWB no joy. trying the main pwb today will let u know how it turns out
      • Practic
        • Oct 2014
        • 56
        Re: TA 6500i Blank screen when power is switched on.
        Does anybody knows the end of the story? Was it main PWB?
        Sent from Ericsson DBH 1001.
