CS-1815 / 1820 Image is not centered, image keeps shifting
  • screwdriver08
    • Jul 2010
    • 160
    So I brought this CS-18215 from a friend of mine. I bought it with a error code C6000, I finally fixed that problem with the fuser. Now it prints, the only problem is that everytime it prints out the leading edge is off and it doesn't repeat, everytime it prints either the image is moved way way up or sometimes not so much that it is ALMOST the same as the original on the glass that I am making copies of.I am lost and not so sure what to do with it.any suggestions would be greatly appreciated
  • Zackuth
    • Aug 2009
    • 448
    Re: CS-1815 / 1820 Image is not centered, image keeps shifting
    The feed tire might be dirty or worn. You might need to clean or replace that. It could be the the registration clutch is greasy. I would take both the registration and feed clutch off and clean with alcohol.
    If at first you don't succeed, redefine success
    • Tonerkiller
      • Oct 2012
      • 669
      You need new solenoids for the feed and reg clutch. The noise reduction pad is stickey. You can test this by actuating the solenoid by hand and you will see it sticking
      • darry1322
        • Oct 2010
        • 817
        This -->
