Kyocera Taskalf 4500i Jam 0518
  • spiderman76
    • Mar 2009
    • 59
    [Error Code] Kyocera Taskalf 4500i Jam 0518
    Hi Guys !!!
    Problem , problem , problem .... TaskAlfa 4500i with Finisher,Mailbox, cassette 2*550 and Dp...
    The paper Jams ALWAYS in duplex mode ( jam code 518 ) .
    Ideas ????
  • madas
    • Aug 2008
    • 313
    Re: Kyocera Taskalf 4500i Jam 0518
    Heard that some of this range of TA (ci ) has clutch issues getting rusty/corroded not sure if it applies to this model also?
    madas
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • 20gaugeO/U
        • 554
        Make sure the finisher is level and depending on when it was manufactured check the 3500/4500/5500 Troubleshooting Guide. Kyocera made some changes to rollers, bushings and gate in the Attachment kit area.
        • tonerleak
          • Mar 2012
          • 67
          We have 200-300 of these units and have had at least 2-3 dozen problems of this kind(J518 J4113,J4413),all in duplex mode. We have been replacing complete conveying units (which are warrantied) and once replaced, problem is permanently solved. I know this sounds extreme to a lot of 'old school' techs but a lot of these accounts have swapped out their small personal printers in favor of a few MFPs per floor and downtime is not an option so replacing a complete unit eliminates all the problem component(s) in one fell swoop.
          • tonerleak
            • Mar 2012
            • 67
            Hey spiderman, I just noticed you're in Bergamo, I am visiting my cousin there mid-june. How's the weather? Are you in Citta Alta or Bassa?
            • Tjompa
              • marley
                • Sep 2010
                • 58
                problem solved ?
                I am interested
                hello
