cs255c scan to email and ftp error
Re: cs255c scan to email and ftp error
Host name not found eh? After plugging in DNS info, did you reboot the copier? Also, are you sure it's good DNS info? Some times, if it doesn't resolve quick enough for the Kyocera, it'll give you that, in which case, I plug in the Default Gateway as the primary DNS.. Also, do you mean CS 2550ci or 255c? I'm not sure 255c is good with 587 and TLS support...
