KM-1810 J98 Error Code
  • msiallen
    [Error Code] KM-1810 J98 Error Code
    A J98 error code came up on my Kyocera KM-1810. I ordered a new laser and replaced it. The copier worked for about 10 days and now J98 shows up again. Besides a bad laser, does anyone have any suggestions on anything else that I could try?
  • JustManuals
    • Jan 2006
    • 9838
    Re: KM-1810 J98 Error Code
    Paul@justmanuals.com
    • MR Bill
      • 532
      C400 is the code you get if you have a bad laser. J98 would be a user code. I think J means JAM. Look in the owners manual? Paper jam somewhere? Go back and look.
      • aekovitch
        • Oct 2009
        • 25
        BONJOUR; je crois que c'est le switch avant transfert il faut le nettoyer ;merci
        • kkendric
          • 301
          On the CS/KM 1810 the laser error error actually appears as A400, however I have seen J98 caused by a laser as well. I think this is because for some reason, on some machines the laser error triggers after the paper has started to move triggering the J98 error instead of the laser error.
          • msiallen
            What is so puzzling is that we replaced the laser, there are no jams, and it is still throwing up the code.
            • MR Bill
              • 532
              Pull the laser out and remove the 5 sided mirror and put the smallest drop of oil on the mirror shaft. Not sure where you got the laser unit. Was it a rebuild? I have done this if the mirror shaft is not to bad and it works great. Again, just a tiny wipe with oil on the shaft.
              I got the book out and it says C400 for the laser but I also have seen A400 . Same deal, bad laser. But I never had a machine go into warm up with a bad laser? It would throw the code during warm up. Anyway good luck.
              • aekovitch
                • Oct 2009
                • 25
                Il faut nettoyer le detecteur de papier qui se trouve en bat juste avant l'entrer du chauffage
                il sert pour le debut du transfert e
                • MR Bill
                  • 532
                  My german is not too good. If that is german. What did you say?
                  • aekovitch
                    • Oct 2009
                    • 25
                    il faut nettoyer le detecteur de papier "switch"
                    • MR Bill
                      • 532
                      I think the guy is saying you have a exit switch that is bad. I do know those exit switches become defective from the fuser heat. Might be worth a try.?
                      • ZOOTECH
                        Senior member of CRS
                        • 3375
                        Mr Bill, download Google Translate, it helps tremendously. (it's actually French)
                        "you should clean the detector paper "switch"
                        • JR2ALTA
                          • Feb 2010
                          • 2033
                          how do you translate "worthless advice" back to French
                          • MR Bill
                            • 532
                            I think if the question is asked in English then the anwsers shoud likewise. That's the only language I know so I guess I'm not as educated as some. If I lived in France or Quebec Canada I would be able to speak French. If I lived in Mexico I'd know Spanish . But here in the states all you are required to learn is English. French is such a funny language anyway. When they say yes they use the work Oui. That's what I do when I go pee. OUI, OUI. LOL.
