FS-1028 print using an usb drive
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    hi to all,
    i have kyocera FS-1028 ,when i plug the usb drive in the slot and after , it shows "CANNOT CONNECT TO THE USB DEVICE"
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • tonerleak
    • Mar 2012
    • 67
    Re: FS-1028 print using an usb drive
    see if maintenance mode u221 is on/off
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      There is Nothing in maintenance mode u221 !!! it is 1028 serie , i want to printing from USB drive
      DAMENE ABDEL AZIZ
      DJELFA
      • kibbs
        • Apr 2013
        • 94
        goto system menu then system-> then network turn off the tcp ip-> then you can try with the usb printing... it will work...
        • kkendric
          • 301
          There are limitations as to what type of files can be printed from a USB drive. PDf, TIFF and XPS appear to be the only files acceptable for printing so the file extension must be .pdf, .tiff or .xps. or they will not be recognized.
          • sweet.persona
            Engineer
            • Nov 2009
            • 414
            thank u for all
            DAMENE ABDEL AZIZ
            DJELFA
            • Eric1968
              • 2458
              Turn on TCP/IP to print from a USB-stick????? That's the same if I change the tyres of my car because it won't start...
              • sweet.persona
                Engineer
                • Nov 2009
                • 414
                i turn the tcp ip Of but there is No result i cannot print from the usb drive , and when i match USB cable to print from PC , the pc doesn't detect the machine !! i tyred to print from others PC but nothing!!
                DAMENE ABDEL AZIZ
                DJELFA
                • Venom
                  Technical/IT Support
                  • Nov 2009
                  • 765
                  i don't think print from USB was an option on the 1028
                  IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                  • B0265
                    • Jan 2007
                    • 718
                    Have you tried with another USB stick?
                    • kibbs
                      • Apr 2013
                      • 94
                      when u insert the usb cable then goto to device manager whether your cable is in good condition or not..the cable is detected in your pc.. their u will cum to knw..
