MAC 10.8 Account Code Prompt
  • CraiginAK
    • Jan 2013
    • 88
    We just put a 5550CI in an almost total MAC environment running 10.8 Mountain Lion I think its called. They use account codes and it doesn't prompt for account code like the pc's do. We do know how find it but it's not easy and customer not so happy about it. Is there something we did wrong or is it just way it is when using MAC software ? We do a few MAC's but not run into this before. Thanks for any help.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: MAC 10.8 Account Code Prompt
    Ya it isn't as easy...what version of driver are you using...I haven't tried mac ver 3.0 yet, maybe easier?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • CraiginAK
      • Jan 2013
      • 88
      The latest one on the site.
      • emujo
        • Jun 2009
        • 3009
        When you select print and the dialog box opens you have a drop down to select things like 2-side, staple etc. One of these options should be "Output". There is an authentication check box which when selected will open the account code input settings. These should be able to be saved. Emujo
        • darry1322
          • Oct 2010
          • 817
          The problem I've always had is that some customers want the driver to PROMPT for the account code on each job. You have to use this drop-down and change the code for each print job. We have lawyers, accountants who have accounts set up for each client so they can bill for copier usage.
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            No prompts on the Mac OS, sorry.
            Never have seen one for any make or model.
