I have a problem with Kyocera FS-C5025N.
On the absolutely left edge there is a blue streak from upside down through whole page.
I removed blue toner, developer and tried to remove drum and I only little lift up the drum, after that the streak is only from first half of the page and dissapeaing to the left edge.
The tried drum cleaning mode and it doesnt helped.
Service manual saying it can be bad drum cleaning blade and to replace it, bad transfer unit or transfer cleaning unit, or try to clean corona charge wire.
Scanned example is here:
I will appreciate any suggestions.
Thanks.
Thanks.
