Copystar CS205c temperature
  • wbosque
    • Aug 2013
    • 4
    Hi, I'm working on a CS205c that display "High temperature. Adjust room temp". I check in the maintenance code U139 plus the room i'm in and it look and feel perfectly find. Any way I can reset the machine so it won't appear again? Any help will do thanks.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Copystar CS205c temperature
    Paul@justmanuals.com
    • blsquires
      • Nov 2008
      • 342
      two things ,1 if the filters are blocked it can do this.2 i also had one giving the same problem ,it was sitting under an evap aircon outlet .moved the machine and everything was ok.
