incoming fax store in document box
  • darkmaster
    • 50
    [Misc] incoming fax store in document box
    I have a problem at Taskalfa 3050ci. How to i configure all incoming fax store in machine's document box then machine can forward stored fax to PC, is possible?
    After machine complete to forward all stored fax to PC, the PC will pop-up notification or alert message. If not mistake minolta machine can perform this kind of function. Everybody any idea?
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: incoming fax store in document box
    I believe you can still use scan file utility to forward fax with pop up notification and send to email. As with all newer Kyo's the FTP protocol is used.
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • darkmaster
      • 50
      scan file utility is kyocera utility or need to download from third party?
      • Venom
        • Nov 2009
        • 765
        scan file utility is from kyocera, only authorized dealers can download from kdaconnect
        • darkmaster
          • 50
          Thank you for your information.
