Light black copies taskalfa 3050ci
  • vedder
    • 131
    Hi everyone, got a bit of a head scratcher and any help would be very much appreciated.
    We have a Utax cdc1930, which is a taskalfa 3050ci which is giving washed out black copies, only poor black, all other colours perfect, we changed the K dev unit, did all the dev set ups etc and the machine was fine, but after a day or so, the black was faint again, running a dev refresh and calibration brings it back up but it doesn`t last.
    What we noticed was the black toner sensor control on auto is alot lower than the other readings at 138, the colours are up at around 160, if we put it on manual toner sensor control, the black stays black, but the colours overtone, but then if we take back off manual and on to auto, it goes back to under toning.
    Just putting this out there to see if anyone has any suggestions as it is causing a few headaches, the firmware is all up to date, and all set ups have been done.
    Any help or suggestions on this would be very much appreciated.
    cheers.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Light black copies taskalfa 3050ci
    Paul@justmanuals.com
    • EricToner
      • Sep 2013
      • 5
      cheers.
      Hmmmm.... Are you using OEM or compatible toner?
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        if dev refresh only lasts a day and you have a new dev unit installed, then I would try new drum unit
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
        • mossup
          • Nov 2012
          • 26
          I am having a similar problem on a TA7550ci , We have changed out the following Dev unit,Drum Unit ,LSU unit Drum Drive motor ,Dev drive motor,Transfer unit , Version 7 FW . The customer have been refreshing dev themself when it goes faint which is about once a day. Have a feeling its losing dev and then going faint, going to try HVT pwb and replace the drum and dev at the same time .
          • copymech
            • Sep 2011
            • 196
            The hvt contacts for the transfer belt can come loose causing intermittent contact for that color. Usually causing faint t ransfere.
            • NeoMatrix
              Senior Tech.
              • 3514
              Sounds like the customer may have their MFD or printer driver software set to "eco" or " save toner mode" This will print blacks in lighter grey scales. Advise the customer to change this setting.
              • 24dude
                • Jul 2012
                • 10
                definitely check the eco settings they can be adjusted for copy and print in system menu..
                • Haddat
                  • Apr 2011
                  • 13
                  What is the result?
                  • mossup
                    • Nov 2012
                    • 26
                    Not sure about the others,but we had to change the machine to keep the customer happy, after numerous visits with Kyocera we still couldnt find a solution.
                    • Haddat
                      • Apr 2011
                      • 13
                      I'm sorry .. I will do the same thing ..
                      • Haddat
                        • Apr 2011
                        • 13
                        Kyocera is the quality of the final model is quite lowered .. you what do you think about this ?
                        • mossup
                          • Nov 2012
                          • 26
                          The Alphard 2 range seem much better, but still poor quality, we sell Sharp Copiers as well and overall build quality is much better , but even sharp machines aren't as good quality as they used to be, seems everyone is cutting costs somewhere, found on the Kyocera machines that they use poor quality clutches and cause intermittent jamming issues. The 7750ci we had the problem with had every thing replaced and we still coulnt crack it , very frustrating . we replaced the machine with a 7551ci and all is well, not had the problem on any other of our machines.
                          • ChrisW
                            • 6
                            Anyone find an answer to this problem besides replacing the machine?
                            I'm having same issue with a 4550ci except that problem also occurs on other colors (Not just black). Customer runs much more full color than black & white.
                            Have replaced drums and dev units. Inspected transfer belt and ID sensors.
                            Running calibration seems to fix it but often returns in less than a day.
                            Have noticed that machine is logging error code 7601 very frequently. This error is logged only and is not displayed - You must check error history to know if this is occurring. Initially I was thinking the 7601 (Front ID Sensor Error) was occurring due to the density dropping out. That it was a symptom and not the problem. Now I am thinking that the ID sensor or a connector / wiring maybe causing the problem. Has anyone else noticed this error when problem occurs?
                            Thanks for any input or thoughts.
                            • rashid120
                              • Jun 2010
                              • 76
                              cheers.
                              Dear Friend.
                              please change this part....PARTS UNIT HIGH VOLTAGE TRANSFER SP....PART NO: 2K994401.i am sure your problem will be solved.Black sensor value is much lower than other colors. that's fine no need to change any value.
                              Good Luck
                              Thanks and Regards.
                              Rashid Iqbal.
