IB-51 Wireless Card for use in TA-2550ci
  • Caz_101
    [Misc] IB-51 Wireless Card for use in TA-2550ci
    G'day there, As we know the new TASKalfa range has support for a wireless card (Which is about time :/ ). Anyway I've heard a few techs in the field say you can get the IB-51 working on the smart series based TA-2550ci. Has anyone had any experience doing so? I know its not supported officially but it has the same base connector on the board to fit into the TA Series. Could only assume its a Firmware based issue at this stage.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: IB-51 Wireless Card for use in TA-2550ci
    Why would anyone install a wireless card when you can setup a wireless router in pass through mode for a fraction of the cost?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • tcook
      • Apr 2013
      • 37
      We had experience with an older KM-2550 wireless card (IB-22), and it was a nightmare with dropped signals. Ended up doing what Venom referenced and set up a router. Never a problem again.
      • Jules Winfield
        • Jul 2009
        • 821
        Back in the old days (IB-22 era) when scanning was on a second NIC, you would still have to use a wireless ethernet bridge to get the scan function to work wirelessly even with the IB-22 installed for printing. And yeah, the bridge thingy is way cheaper and is easier to set up. I would just go that route instead of the IB-51 route...
        But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
