Jam Code 1314 TA-8000i
  • djfenti
    • Nov 2012
    • 20
    [Jamming] Jam Code 1314 TA-8000i
    Hello all and thank you for reading my post.
    On a TaskALFA 8000i machine, Im getting an error code J1314. The troubleshooting guide addresses this problem and points to the PARTS GUIDE FEED MIDDLE ASSY SP #302K994430. Does anyone have instructions on how to replace this piece??
    Thanks in advance,
    David
  • 10871087
    • Jan 2005
    • 1062
    Re: Jam Code 1314 TA-8000i
    Thanks in advance,
    David
    The PARTS GUIDE FEED MIDDLE ASSY SP is item number 302K994130, it looks pretty simple, not sure what instructions your looking for?
    • mossup
      • Nov 2012
      • 26
      Thanks in advance,
      David
      Hi
      Had a few of these , J131X jams , some very intermittent . i would also replace the clutch as well as that is whats causing the jamming in the first place , there are some pads to fit (302K94d70) These are used to stop the convey roller from slipping . Its not too bad a job . follow TB 2LC-0095(C244) it will have step by step instructions.SB-2LC-0095-C244_1.pdf
      Hope this helps
