I just set-up an 1135 at a customers and it won't send faxes. It receives faxes without an issue but when I try to send a fax it says an error occurred and the result says BUSY. Tried reloading latest Firmware, Re-initializing the fax board, replaced the fax board, and I've just now tried another brand new machine in it's place and that one does the same thing. So, it isn't the machine's fault exactly but why does their old fax machine work fine sending and receiving and the 1135 won't? Any advice is appreciated. Thanks!
FS-1135 won't send faxes?
Just because you're not paranoid doesn't mean they're not out to get you.
O.o
WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
Re: FS-1135 won't send faxes?
I don't know much about the FS-1135, but maybe lowering the baudrate can be an option. If the customer is sending faxes via the Internet, lowering the baudrate to 9600 kbps may work. I have one customer that uses VOIP-lines to send and receive faxes and I lowered all baudrates to 9600 kbps. 14400 kbps and 33600 kbps didn't work, but 9600 kbps gave no problems. -
I printed out the settings on the old fax machine and now I have to do some research and see what I'm missing.Just because you're not paranoid doesn't mean they're not out to get you.
O.o
I just set-up an 1135 at a customers and it won't send faxes. It receives faxes without an issue but when I try to send a fax it says an error occurred and the result says BUSY. Tried reloading latest Firmware, Re-initializing the fax board, replaced the fax board, and I've just now tried another brand new machine in it's place and that one does the same thing. So, it isn't the machine's fault exactly but why does their old fax machine work fine sending and receiving and the 1135 won't? Any advice is appreciated. Thanks!Comment
Turn of v.34 mode, it will override many baud and ecm changes you make if it is left on.
BTW, see if it works if you manually send the fax. go off-hook, then dial the number, wait for the handshake and then hit send. If this work and memory transmit doesn't than they need an actual old-school telephone line. Faxing over modern IP phone system isn't reliable and never will be.Comment
do you hear a dial tone? you may need to shut off dial tone detection to get it to send outIBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ CertificationsComment
MEISTER
I believe they do have an old-school telephone line.
Originally posted by JustManuals.comThis Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
Paul@justmanuals.com
How?
Thanks everyone for the responses! Sorry I don't know how to do all these things to these machines. I'm pretty new to Kyocera machines but I'm liking them a lot so far!Just because you're not paranoid doesn't mean they're not out to get you.
O.o
MEISTER
For anyone interested:
U631 - ECM settings
U633 - V.34 settings
U650 - G3 settings
I was able to manually send a fax but couldn't get it to send on its own. I tried all different settings in those modes in various combinations without success.
What did end up fixing it was in U660 under EXCHANGE, I switched it from PSTN to PBX and it worked fine after that.
Thanks everyone for the help!Just because you're not paranoid doesn't mean they're not out to get you.
O.o
