Morning all. I have a FS 6525 with f 245 as soon as I turn it on. The copier has no fax any options or has ever been- connected to network. Just a stand alone. I have tried f/w upgrade without any luck, refitted all connectors and also unable to enter service mode. There is no f 245 in the manual. Any one got any ideas?
fs 6525 error code f 245
Re: fs 6525 error code f 245
This might help! never tried it though.
madasF245 CF245 may be caused by SATA cable abnormality. Please change SATA cable. (302K946A20 or 302K946760) 2LC-0077 C103 Please change SATA cable. (302K946A20 or 302K946760) Comment
Did you ever figure this problem out? I'm going out on one today that the customer said was working fine and then started making both black copies and prints. She unplugged and replugged and is now getting f245 which I've seen once before but it cleared by unplugging it. Weird code that's not in the service manual. Machine had latest firmware installed about a year ago, never had any problems with it.Comment
either way it would be best if you started an new thread and list ALL the issues and Life counts of parts and what you have tried/doneComment
