Kyocera FC-C5300N
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5014
    Kyocera FC-C5300N
    Hi
    I'm Canon tech and i need advice from Kyocera tech. With this Kyocera FC-C5300N i have background color issue.(look pdf pic).First I suspect yellow developer(first picture) and i put the new one. Same shit.
    After that i change yellow and cyan drum to each other and get second picture with blue background.I suspect yellow drum.Maybe Main charger or Eraser lamp? What do you thing guys?Kyocera FC-C5300N.pdf
  • Tebow83
    • May 2009
    • 92
    Re: Kyocera FC-C5300N
    Originally posted by zoraldinho
    Hi
    After that i change yellow and cyan drum to each other and get second picture with blue background.I suspect yellow drum.Maybe Main charger or Eraser lamp? What do you thing guys?[ATTACH]22494[/ATTACH]
    Have you tried just switching the charges to see does the problem switch?
    • Eric1968
      • 2458
      Change the complete yellow drum unit.
      • zoraldinho
        • Mar 2008
        • 5014
        i didn't know.It's separated part.Later I so in parts catalog.
        • zoraldinho
          • Mar 2008
          • 5014
          i'm gona do that.Thanks.
          • JustManuals
            • Jan 2006
            • 9838
            If you want a free copy of the parts & service manual, just email me at paul@justmanuals.com . And remind me who you are.
            Paul@justmanuals.com
            • zoraldinho
              • Mar 2008
              • 5014
              Thanks Paul.I appreciate that.
