Taskalfa 180 Firmware upgrading !!
  • sweet.persona
    Engineer
    • Nov 2009
    • 414
    hi to all
    i've learned some information to upgrading the firmware in TASKALFA brand , but i noticed that i need for (compact flash) to upload it!
    i want to know if there is another Method use in it an parallel port or usb to Contact it nd send with an interface more easy!
    By the way i am searching in some diagrams , to make another method more simply and
    ensured.
    Best Regards
    A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
    DAMENE ABDEL AZIZ
    DJELFA
  • kkendric
    • 301
    Re: Taskalfa 180 Firmware upgrading !!
    I am rather surprised that you have been a member since 2009, have 351 posts and still do not know how to perform a firmware update on a Kyocera Mita copier. To update the firmware in this model you must use a CF (Compact Flash) card.
    Maybe, just maybe it also would be a wise idea to purchase a service manual for this model. The way to make your customer happy is to do the job right the first time.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • sweet.persona
        Engineer
        • Nov 2009
        • 414
        D&ar friend :
        right, i am member since 2009 in this forum, But don't forget that i am a CANON ENGINEER from 1998 not kyocera, for that i haven't resolved a lot of KYEOCERA MACHINEs , my big focus was in CANON and RISO, RICOH brands ,don't Wonder because i have many Inventions in this field !
        Best Regards!
        DAMENE ABDEL AZIZ
        DJELFA
        • kkendric
          • 301
          Most of your Kyocers power supplies will shut down if thet detect too much current. So you might start by disconnecting connectors one at a time and see if the fan keeps operating. I am not so sure this is a firmware issue. You first stated when the copier was turnes on the fan started to run but quit, this leads me to think of possible shorted components or something drawing too much current shutting down the power supply. I know for sure on the KM-3035 series that if the PSU detects too much current it will shut down and has a 10 to 15 minute delay until it will turn back on. I could be wrong but with no display and fans trying to turn on but dont it might be worth a try.
          • sweet.persona
            Engineer
            • Nov 2009
            • 414
            Thanks friend kkendric i've seen more time in it but (teckat) told me that i need for FIRMWARE but i want to know where is the PORT IN MACHINE
            thank u in advance.
            DAMENE ABDEL AZIZ
            DJELFA
            • kkendric
              • 301
              Upper Right rear of machine metal cover with one screw. An engineer should also know the value of using the right tools, including a service manual!
