kyocera taskalfa 820i error C2300
  • kibbs
    • Apr 2013
    • 94
    Dear Friends,
    Kyocera taskalfa 820i error C2300.. last weak i change the gear wheel in the drive section.. @ the time one of the gear is broken.. after i replaced at the time machine is okay for one weak.. but today i receive the c2300 code in that machine.. but when i switch one the machine.. fixing lever is rotating after within in a second i am getting C2300..
    the picture i attached which it is rotating while swicthing on the machine.. there is no gear breaking sound.. sounds are fine like working condition but suddenly code 2300 appeared..
    Note: i changed the all the gear in drive section... not the motors..
    thanks & regards
    kibbs
  • wbosque
    • Aug 2013
    • 4
    Re: kyocera taskalfa 820i error C2300
    You might have a bad fuser motor. try going into the maintenance mode and enter U030 and check the operation on the fuser motor. you could hear the motor run.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
