Kyocera FS-C2126MFP - SSL support
  • diizzy
    • Jul 2025
    Hi,
    I have a FS-C2126MFP that's approx 2-3 years old, never had a firmware upgrade and such. The new mail provider wants SSL auth which this machine's current firmware doesn't support at all.
    We have a newer FS-C2126MFP+ which does this fine so I figured that its most likely just a matter of firmware version or am I wrong?
    Current firmware versions:
    System Firmware: 2KX_2F00.006.002
    Engine Firmware: 2KW_1000.007.004
    Fax Firmware: 2KX_5100.003.001
    Best regards,
    Daniel
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Kyocera FS-C2126MFP - SSL support
    The firmware release notes does not mention SSL so guess you have to try it.
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
