KM 4050 lease return
  • ZOOTECH
    Senior member of CRS
    • 3375
    I've seen conflicting information whether this machine has a HDD or not. If not, no problem returning to the recyclers; if it does, how do I clear all customer info before sending to the recyclers?
    Thank you in advance...
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: KM 4050 lease return
    Well you can U024 to format the HDD...and yes they have them...and they are not fun to get to....I had to yank a set out of a few 5050's from the local police dept...it sucks...
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • ZOOTECH
      • 3375
      Will formatting the HDD make the machine unusable? Is U204 accessed by 10871087? Thanks for your help.
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        U024 not u204(this is for a key counter)...and this is what it does
        Initializes the HDD.
        In addition, the following settings are also initialized by initializing the HDD.
        System menu (user login administration, job accounting, address book, one-touch keys and document box
        etc.), shortcuts and panel programs
        It will not make the machine inoperable. I format HDD's all the time. If there is info on them you do wish to save you can export and import that info with u917.
        • ZOOTECH
          • 3375
          Sorry, my dyslexia kicked in - thanks, this is the info I needed.
          • CraiginAK
            • Jan 2013
            • 88
            Technically even after formatting the information is still there. If being required do this because of some business or contract then to do it correctly need to have it wiped to DOD or other standards. I know for a contract we had, before we got the software had send them Hytec and get certified that they were sanitized and customer wanted see the cert after it was done. If our customers concerned we offer it as service when getting rid of there old copiers. Also bit of revenue enhancement if want it to be, certainly easy enough to do. The software not real cheap but we have made our money back and it allows us to print our own certificate once done.
            • ZOOTECH
              • 3375
              OK, back to step 1; I've got the machine in the shop, but am unable to access service mode. I'm not sure of the procedures to get into service mode - when I hit the 'System Menu' key, page 1 of 2 shows up, but the touchscreen is dead.
              I can press the 'Copy' mode key and it returns to copy mode. Please help a rookie KM tech (No, I didn't volunteer for this). I don't think we need a DOD wipe of the drive, just customer saved information cleaned up.
              • CraiginAK
                • Jan 2013
                • 88
                To get a Falcon III into service mode you have to push Status/Job Cancel first. Then do the 10871087 then go to mm# 24 to format hdd. If panel is dying meaning can't select things on touch screen going make bit more difficult but hopefully it will let you select execute in mm # 24 so can get it to format.
                • ZOOTECH
                  • 3375
                  It worked like a charm - thank you so much.
                  • Venom
                    Technical/IT Support
                    • Nov 2009
                    • 765
                    U24 doesn't really wipe the drive, you would need a program to rewrite 0's and 1's several times
                    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                    • nmfaxman
                      • 1702
                      I reformat any drive, then print and scan 10 test pages to and from my laptop with a crossover cable.
                      I delete or restore a blank address book backup.
                      Reformat again.
                      Copiers are limited to a 10 document queue that overwrites the last 10 jobs.
                      Even if a lowlife hacker searches the HDD, there is nothing more than test prints and scans.
                      Time used, about 30 minutes and HDD is clean.
