TASKalfa 620 "optimizing Continuesly"
  • Tomsakzn
    • 7
    [Misc] TASKalfa 620 "optimizing Continuesly"
    Good day all
    I have a problem on a TASKalfa 620, It keeps on "optimizing"
    I have replaced the HDD and done Firmware, Switched off the DRUM heater.
    Any Idea what else i can look at?
  • Tonerkiller
    • Oct 2012
    • 668
    Re: TASKalfa 620 "optimizing Continuesly"
    The only times I have seen this problem is where there is too much heat in the room. Clean the machine filters cl the drum heater contacts. I would leave the drum heaters on. They keep the charge decay rate at a constant value.
    • blsquires
      • Nov 2008
      • 342
      I agree with toner killer .clean or replace all filters make sure the machine has room around the back so air can flow .
      • dyodyo
        • 28
        I agree with Tonerkiller as well.
        But if the problem is not resolve after cleaning/replacing the filters then check if all the fans are working.
        If one of the fan is not working the machine will keep on giving you this "optimizing" message.
