kyocera FS - 8025 MFP sound in the fuser section
  • kibbs
    • Apr 2013
    • 94
    Dear all,,
    Can anyone face Fuser section abnormal sound Problem in kyocera fs 8025mfp ??? ... when i switching on time and also after machine printing job completed after 2 minutes sound coming from fixing section... i adjusted the fuser section screws also still same.. any service bulletin is their for this issue..
    thanks & Regards
    kibbs
  • 20gaugeO/U
    • 554
    Re: kyocera FS - 8025 MFP sound in the fuser section
    IMAG2112.jpgTake out the fuser drive unit p/n: 302K093131 DR-895B Not hard to do.
    Inside this assembly, off the fuser drive motor is a POLYSLIDER WASHER p/n: 2FT18370. I'm going to bet the spring that rides on it has worn through the washer and is "knocking" on the metal frame. I was able to get some washers from hardware store for 43 cents. Still in the testing phase but they should last longer doubled up and with some lubrication.
    They used this same drive unit on 205/255c and 2550ci and 2551ci units. Also setting Energy Saver on these models still keeps the fuser slowly rotating...Sleep timer will halt the fuser from rotating.
    Good Luck
