3200 error code, what is it?
  • eg101
    • Jan 2005
    • 131
    Setting up a new FS-3640. After warm up 3200 shows in the screen with instructions to turn off and on. Done that 10 times with no effect. I work for a dealer but normally on Konica Minolta copiers. Anyone know what this code means and how to reset.
    T I A
  • Morlock49
    • Mar 2009
    • 166
    Re: 3200 error code, what is it?
    T I A
    Exposure lamp error
    When input value at the time of exposure lamp illumination does not exceed the threshold value between 5 s
    Possible causes
    Defective connector cable or poor contact in the connector
    Defective exposure lamp or LED drive PWB.
    Defective CCD PWB
    Defective main PWB.
    Silly question but have you released the scanner locks.
    Sorry folks, reputation removed by Just Manuals, because he's a sad little wanker
    • eg101
      • Jan 2005
      • 131
      Thanks. Found it!
      • Morlock49
        • Mar 2009
        • 166
        so what did you do to resolve the problem
        • eg101
          • Jan 2005
          • 131
          Doc feeder was in a bind. Machine worked o k with doc feeder open, threw error code when closed.
          Took feeder off and re-seated - works.
          Go Figure.
          • MR Bill
            • 532
            Thanks for letting us know what the fix was. I would have been up all night if you hadn't. LOL. No it really helps.
            • kkendric
              • 301
              Go Figure.
              Never heard of a DOC feeder causing an exposure lamp error, you sure that you didn't just forget to unlock the scanner when you setup this machine ?
              You know we are all human.
              • eg101
                • Jan 2005
                • 131
                Scanner was unlocked, it didn't make the LOUD rattling noise when you forget.
