Copy Light TA-5550ci
  • kaborwen
    • Feb 2010
    • 146
    [Misc] Copy Light TA-5550ci
    Hi all,
    I get a problem with a TA-5550ci. The prints and copies are very lignt ( see Att. file).
    Need help!
    Thx.
    doc03455020140417173937.pdf
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Copy Light TA-5550ci
    Looks like you have no transfer
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Eric1968
      • 2458
      X2
      Print a Color pattern (U89) and open the conveying unit during printing to see if the image is clearly visible on the belt. If that's the case check the mechanism that moves the transfer roller to and from the belt. Could also be a bad contact somewhere in the conveying unit.
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service Manual can now be purchased for $14.77 and downloaded immediately from:
        Paul@justmanuals.com
        • kaborwen
          • Feb 2010
          • 146
          Originally posted by Eric1968
          X2
          The image is not clearly visible on the belt. But I findout a bad transistor on the Hight voltage PWB. May be that the problem. I would replace and let you know. thx
          • Jomama46
            • 2900
            Lack of charge on a digital machine will give you a black copy.
            sigpic
            A+; Network +; PDI+
            • Kyo fan
              • Dec 2013
              • 368
              What they said.
              I would just add that you should update firmware to the latest 07.09.0020 version (lots of fixes in it) after replacing that pwb. After the update make sure you perform Color Calibration and than Color Registration Adjustment so that the adjustment values would be correctly reflected.
              • kaborwen
                • Feb 2010
                • 146
                It's not a charge, it's for transfert and separation bias. So my think, it's can be.
                • Jomama46
                  • 2900
                  Then you may be right
                  sigpic
                  A+; Network +; PDI+
                  • kaborwen
                    • Feb 2010
                    • 146
                    Hi all,
                    I replace the transfer hight voltage PWB and all is ok.
                    Thanks all.
                    • Jomama46
                      • 2900
                      Originally posted by kaborwen
                      Hi all,
                      Thanks all.
                      Thanks for the feed back.
                      sigpic
                      A+; Network +; PDI+
                      • jmaister
                        certified scrub
                        • Aug 2010
                        • 755
                        FYI, a flooded machine would do this, if it turns on at all.
                        Idling colour developers are not healthy developers.
