Copystar CS4550C C1950
  • buddy1189
    I am getting a C1950 code replaced transfer belt, harness to engine pwb, and engine pwb. Code is still happening any ideas.
    Thanks,
  • blsquires
    • Nov 2008
    • 342
    Re: Copystar CS4550C C1950
    Transfer belt unit EEPROM error
    No response is issued from
    the device in reading/writing
    for 5 ms or more and this
    problem is repeated 5 times
    successively.
    Mismatch of reading data from
    2 locations occurs 8 times
    successively.
    Mismatch between writing
    data and reading data occurs
    8 times successively.
    1. Confirm that the power connector is
    firmly connected and, if necessary,
    connect the connector all the way in.
    Engine PWB (YC27) and RFID PWB
    (4P connector)
    (Check wirings on the RFID side since
    the signal line for the intermediate
    transfer belt sensor EEPROM on the
    engine PWB and the signal line for the
    toner container RFID are the same.)
    Transfer belt unit and Engine PWB
    2. If the wiring is disconnected, shorted or
    grounded, replace the wiring.
    • Tonerkiller
      • Oct 2012
      • 665
      Like he said. I got that error one time because i did not have the transfer belt plugged in.
      • buddy1189
        successively.
        successively.
        (4P connector)
        Checked wiring everything checks out good any other ideas machine after throwing code shows front door open when it is closed.
