Kyocera km1650 cant access printer web
  • Guest
    Hi,
    I have a kyocera km1650 with 0.0.0.0 all protocol ip block,
    how can i reset it to default settings without accessing web interface?
    best regards
    thanks
  • copymech
    • Sep 2011
    • 196
    Re: Kyocera km1650 cant access printer web
    Mode 21 should reset copier to factory defaults. Including network settings.
    • A\ztech
      • Feb 2011
      • 57
      Try sim 906 , the print feature might of got disabled
      • rana
        • May 2014
        • 19
        Originally posted by hugohug
        Hi,
        best regards
        thanks
        try u906 .if you are not got you have to check the eprom of the machine the ip protocol is not showing means the program data be not finded the machine but definitly you have to check the eprom.
        any way all the best
        • Guest
          Thanks for all
          nor u906 u21 worked, ip block still there.
          I can access the scanner ip and web but not the printer ip and web.
          i have tried with most of the options in the "10871087" menu.
          what more can i do?
          thanks
          • rana
            • May 2014
            • 19
            Thanks for all
            what more can i do?
            thanks
            you check the eprom can you re insert the e prom and rest the machine after its works
            after that tell us
            • kkendric
              • 301
              Do you have two network cables connected? One for the scan system and one for the printer? This copier uses Scan system F which is connected to the main board.
              • Guest
                yes, this printer have two ethernet, one for the scanner and one for the printer.
                the scanner is working nice, the problem is with the printer unit.
                I tried removing two board batterys but the config is still there.
