KYOCERA KM 3050 dirty with toner half sheet on the back
  • tecnomarco
    • Jul 2011
    • 213
    Greetings all, I have this problem on KM 3050 the first 2-3 copy or print dirty with toner half sheet on the back, is also the dirty transfer roller,someone tell me what the problem is?I changed the toner, transfer roller, and the drum, but the problem remains
  • copymech
    • Sep 2011
    • 196
    Re: KYOCERA KM 3050 dirty with toner half sheet on the back
    This is a common problem with aftermarket toner. I noticed that the developer hasn't been replaced. It still has the suspect toner in it prior to tonerreplacment. Different brands of toners don't mix to well. Just my opinion.
    • MR Bill
      • 532
      Yes, generic toner. You have to dump out all toner out of dev section and recalibrate with new oem toner. Save on buying cheap toner and lose money on labor trying to make it work. Kyocera equipment does not like comparable toner.
      • rana
        • May 2014
        • 19
        hai and also you check the drum behind paper cleaning roller and one there that one also you change and check
        any way all the best
        • daveh12
          • Jul 2012
          • 157
          Agree with Mr bill, generic toner is the problem. Either hoover out or replace the dev unit and then insert oem toner. Run U130 to refill developer do a few copies. No dirty copies after that.
          • Scott
            • 194
            Compatible toner everytime
            • BSGINC
              • Jan 2012
              • 19
              I have had this when the charge unit does not drive all the way up, such as when a junior tech takes the drive pack open and does not get the cam to home all the way then it will be gray on the back half of the sheet. look to see if the charge unit is all the way up to the drum surface on the front side.
              • kyogenius
                • Jul 2012
                • 136
                I have encountered this problem several times with clients who use generic toner.99,999% of the time its generic toner ,not only on this model but majority of kyoceras
                failure is not an option !
                • Crni
                  • Mar 2014
                  • 54
                  Sometimes i get toner marks on back side of my papers.
                  I clean the black roller(looks like it is from foamed rubber) in left cover that solves the problem. I guess some extra toner stays on him. Using original toner though :/
                  I also need advice how to keep my papers clean in km5050. So post some advices pls.
                  • MR Bill
                    • 532
                    That foam roller on the left door is your transfer roller. Yes, it's spongy. Cleaning that will help. But if you use generic toner it will fill right back up with toner and start leaving spots , etc. Not sure about your other problems dude.
