TASKalfa 250ci black image with fainted stribe in from front
  • flimmer
    • Jun 2008
    • 30
    Can anyone help with this problem. Developmotor, develop, drum, transferbelt han been changed. The problem comes gradualy in about 500 copies/prints.
    First from front end , and then at rear end, see PDF
  • Paddy
    • Jun 2013
    • 9
    Re: TASKalfa 250ci black image with fainted stribe in from front
    Hi,
    just to check:
    Get into Maint.-Mode. Print those Test Charts from Sim089. (Sample Set).
    Is it on all Colours?
    Btw: Newest Firmware on 250ci is 15. Might be good to know.
    • flimmer
      • Jun 2008
      • 30
      Originally posted by Paddy
      Hi,
      just to check:
      It,s only the Black colour. Firmware is ver. 13
      • JVergin
        Service Tech / IT Rep
        • 216
        When you replaced the drum, was the charge roller also replaced?
        I know on the 205c, 2550ci models the charge roller assembly can cause a similar looking problem that will create voids that look just like your example and can also cause marks in the same shape as your voids on prints that are low coverage. Haven't seen the problem yet on any 250ci series but I suppose if there is enough buildup of toner inside the charge roller gears or something causing it not to turn smoothly it could cause your problem.
        • Paddy
          • Jun 2013
          • 9
          Hi,
          Upgrade Firmware is always good on this Type of Machine
          Or just run Sim U119. Maybe Check wires behind the central unit.
          Good luck
          Regards
