Kyocera part numbers
  • kyogenius
    • Jul 2012
    • 136
    [Misc] Kyocera part numbers
    Hi guys,Anyone with an idea if the Kyocera part numbers are same as that of Olivetti for same models, the reason being I need a km 1530/2030 fuser drive gear 19 which Kyocera do not have right now but some guy said Olivetti has got.Thanks once again
    failure is not an option !
  • AlbertK
    • Jul 2014
    • 90
    Re: Kyocera part numbers
    I cant believe no one has answered you yet...
    Yes, the parts are exactly the same but the part numbers will differ in the manuals...
    Between Olivetti and Kyocera, mostly the Main PWB's and some toners and toner drive gears are different.
    Hope it wasn't too late to try
    The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
    • D Colour
      • 217
      I can help you with Olivetti part numbers in the future if you need any. Just let me know.
      Everything that has a beginning, has an end.....
