km-2050 problem
  • jewen25
    • Mar 2009
    • 194
    km-2050 problem
    1.error C0240 manual says that maybe damage the printer board? during,its possibles to disable the printer?
    2.No print when i copies its all white, is this a result of C0240?
    3. LSU/high voltage board/ engine all Ok pls any idea how to resolved this error?
    ERROR HELP ME AND HELP YOU
  • kkendric
    • 301
    Re: km-2050 problem
    1. C0240 Printer Board is not communicating with Main Board. Could be either board, Could also be corrupt firmware on the Printer Board.
    2. Can you print reports from Copier? If reports are good rules out HVT, developing and laser sections. If laser is bad should have a Laser error.
    3. Should not affect copying.
    • jewen25
      • Mar 2009
      • 194
      Re: km-2050 problem
      thanks ken
      when i print report its affair all white i swap the process unit and the developer,HVT unit its seems the-same my suspect the engine board?
      • habik
        • 2013
        Re: km-2050 problem
        I assume you have tried to disconnect and re-connet all connectors on main and HV Board.
        Have you tried PWR supply?
        Firmwares HERE
        • jewen25
          • Mar 2009
          • 194
          Re: km-2050 problem
          tnks. for the reply habik
          i well try the power supply
          • jewen25
            • Mar 2009
            • 194
            Re: km-2050 problem
            i chk the power supply it ok, i suspect the engine board?
            • kyogenius
              • Jul 2012
              • 136
              Re: km-2050 problem
              replace the engine board,dont forget the dimm
              failure is not an option !
              • kkendric
                • 301
                Re: km-2050 problem
                There is no DIMM on the engine board of the CS/KM-2050 copier. However there is an EEPROM dip chip that contains information about the copier that will need to be swapped.
