We have several 300/400ci machines that have the same issue... the black starts to fade out and 'band' across the images... shaking toner, replaced drum/developer, replaced toner cartridge drive assy - all to no fix. Finally noticed on at least two of these machines (haven't tested on the others yet) the gray adjustment either in the sys menu or in U410/U412 will not scan in first prints - S02 errors. Used the color chart and U411/u425 to fix one to complete the U410/U412 adjustments, but the second one did not resolve with the color charts..... anyone else seeing this happen? Any suggestions?? Thanks in advance!!
300/400ci Black Color Banding/Fading
Tags: None
Re: 300/400ci Black Color Banding/Fading
if sim 410 fails, the image printed is too light for the scanner to adjust.
Have you tried different altitude settings ?The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
