Need Firmware for Koycera 400Ci
  • mpbcomput
    • May 2025
    [Misc] Need Firmware for Koycera 400Ci
    Hello, I need to get the firmware for 400Ci, I had to replace the hard drives and CMOS battery, after I reinstalled the CMOS and hard drives I get error code, C0640? I was told I need to install the firmware off a USB stick? Any help would be great, I don't have access to the Koycera portal??
  • ss12
    • Jul 2008
    • 289
    Re: Need Firmware for Koycera 400Ci
    Try formatting the hard drives before you go down the firmware route
    • mpbcomput
      I did try that and different hard drives? Any other ideas?
      • mpbcomput
        Any special way to format them?
        • ss12
          • Jul 2008
          • 289
          service mode u024
          • kkendric
            • 301
            1. Did you install correct drives for this copier? Are you sure that you are not getting a C0840 error now?
            2. Are the Sata data connectors connected to the correct connectors.
            3. Strange that battery was bad . With replacing battery you should get a C0840 RTC error not a hard drive error. Reset copier then reset time.
            4. Should not need to install Firmware. It does not reside on either of the disk drives.
