TaskAlfa 3050ci error C2730
  • dynsam
    • Apr 2011
    • 21
    hi
    the error code C2730 is the transfer release motor inside the transfer belt. i replace the transfer belt but the error is still there. please need assistant asap. thanks in advance.
    Regards
    Dynsam
  • MCC-support
    • Jul 2014
    • 38
    Re: TaskAlfa 3050ci error C2730
    C2730- Secondary transfer release motor error
    Try the Press release motor check (U030) and see what the result is and check the colour release sensor is still in place.
    Also check the paper conveying unit to make sure that the sensors are clean.
    • dynsam
      • Apr 2011
      • 21
      thanks MCC-support.
      i changed a new transfer belt and also the paper conveying unit but still.
      • taskalfaman
        • Nov 2009
        • 137
        Originally posted by dynsam
        thanks MCC-support.
        the solution is to change the motor behind the transfer "roller".
        the error tells you what to do.=> change the ranfer roller release motor.
        if you want to go the easy way, change the complete conveying unit.
        this takes 5 minutes.
        have fun
        • Mahmoud Esawy
          • Jan 2023
          • 1
          This Error Cause Noise at main right door
          Broken Part is the reason , easy to install
          Kyocera Taskalfa 3051ci error c2730 (Housing Release Drive) 302K924782: Buy Online at Best Price in Egypt - Souq is now Amazon.eg
          • Reed
            • Feb 2011
            • 259
            I Went on a machine yesterday with this code. Do I need the motor and the housing or just the housing. (it is making a clicking noise)
            • granata
              • Jan 2012
              • 32
              in 90% of cases, I only change the housing. In some cases I also had to replace the motor and gears.
              • Reed
                • Feb 2011
                • 259
                Thanks for the input. The customer is close, so I may just go pull it out and look at it. I hate making a return trip and not having all the correct parts
