Kyocera Taskalfa 180 dark shade at the back of the copy paper
  • mdm7266
    • Dec 2007
    • 99
    hello. my problem is the shade (not dirt) about 2" on the leading edge at the back of output paper.
    attached is the sample (back of the copy paper) i jammed the paper and found out that the image/dark shade is being transferred at the transfer roller at the back of the paper ( the copy in front is good). i tried to wipe the transfer roller with a clean dry cloth. but still there is the dark portion at the back of the paper. what seems the problem? the Transfer Roller?
    Do i need to adjust some data? Hv, grid, etc?
    I need your suggestions based on experienced.
  • kkendric
    • 301
    Re: Kyocera Taskalfa 180 dark shade at the back of the copy paper
    Use OEM Toner
    • Kyo fan
      • Dec 2013
      • 368
      Since you used poor quality non oem toner, now you have to vacuum dev unit, than put oem toner in, and run U130 to replenish.
