(besides just the 8 wallpapers that come standard?)
can we customize the 01 series Home Screens with a clients logo?
Re: can we customize the 01 series Home Screens with a clients logo?
The short answer is Yes.
I am not sure how but someone who understands JAVA script should be able to.The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there. -
There's software to do this from Kyocera but I couldn't figure out how to make it work. Haven't messed with it in awhile and I don't remember what it was called. Sorry.
Also, if I'm remembering correctly from the learning center videos, you can also upload your own backgrounds by formatting a picture to the right dimensions, saving it as a particular file type, loading it on to a USB, and then you can import it with one of the maintenance mode codes.
I wish I had more specific answers but I haven't actually tried to change the home screen yet. It's definitely possible though.Just because you're not paranoid doesn't mean they're not out to get you.
O.o
WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
File MUST follow this criteria:
size: 480 x 800 pixels
file name: menu_background.png (this is case sensitive and must be exactly as you see it. You may need to edit your file view defaults to show extensions)
file type: png (use a graphics editor that allows saving to .png, you cannot simply rename a graphics file from .jpg or .gif to .png)
copy file to ROOT of USB drive and install at machine through U224. Once installed, other wallpaper backgrounds will not be available until the custom background is uninstalled.
You can also install a startup image which is exactly the same procedure, just a different file name (opening_ext_image.png)Comment
