TASKalfa 3010I intermittent black prints
  • Tonerkiller
    • Oct 2012
    • 668
    We have a 3010i that since it was new very intermittently we will get black prints, then it will work fine. Replaced the drum unit so far and have checked the spring that provides the charge. Next we are ordering a hv. Has anyone else had this issue?
  • AlbertK
    • Jul 2014
    • 90
    The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
    • mad
      • Jul 2010
      • 25
      Re: TASKalfa 3010I intermittent black prints
      i know is old problem, but do you remember the solution? i have the same symptoms on several 3010i...
        See the question right above your post? "Does it happen on prints and copies or copies only?"
        • mad
          • Jul 2010
          • 25
          happens on copies and prints
          used to be narrow black lines (see attachment) but lately is the whole page
          • AlbertK
            • Jul 2014
            • 90
            It most certainly is a High voltage arcing problem.
            What happened before the lines started. Did you or someone else replace anything or work with the harnesses, maybe pinch a wire? I would clean and trace harnesses/ground/live contacts then test MC, DK, HV in that order.
            • marley
              • Sep 2010
              • 58
              It happened to me too on a 3011i, I solved it by replacing the drum unit.
              • Tom
                • 344
                I'm having the same problem this week on a 3011i. I replaced the charge roller a couple weeks ago but they just called back with same issue. I guess I'll try swapping the entire drum assy and see what happens, but these machines are so similar to many others and I"ve never had one do that before.
