FS 1128 mfp DP110
  • tatro35
    • Jul 2025
    FS 1128 mfp DP110
    Has anyone had the pick up roller clutch just click in the DP and not turn I replaced the DP main board and clutch still the same issue and updated firmware
  • allan
    RTFM!!
    • 5462
    Re: FS 1128 mfp DP110
    did you remove the rubber damper pad from the solinoid? if not do that. sorry that is for paper jammimg.
    Whatever
    • Kyo fan
      • Dec 2013
      • 368
      Replacing the cable that connects the dp board with the frame (main pwb) will fix it. The cable part name is CONN. CORD ASSY INTERFACE.
