How to setup scan to server on KM-3530 ?
  • HDClown
    • May 2008
    • 15
    Need to setup scan to server on a KM-3530. I downloaded the following utilities from KM:
    Address Book Utility
    Address Editor
    Scanner DB Assistant
    Scanner File Utility
    I want to put a few address book entries in the MFP and have it scan directly to folder(s) on a Windows 2003 Server over SMB. I don't mind editing the entries in the scanner web GUI directly if it means not needing another piece of software.
    Which of the above utilities is necessary to accomplish this task?
  • schooltech
    School District Tech
    • Jun 2008
    • 504
    If I recall correctly, you will need the scanner file utility & the address book utility.
    Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
      • 30218
      scan
      you only need the scan to file run in service mode
      create the folders than in the scan to file setup set them up 001,002
      web into scanner on machine and register in sender list and destination list
      bam your done
      • schooltech
        • Jun 2008
        • 504
        Well, it looks as though I was thinking of a different model. Sorry about that. I did set up some of the older KM's and used those two utilities. And, I know that the newer models will do SMB scanning.
        • KyoceraNSM
          You can download a SFU from Kyocera for the Falcon 3 series. Allows you to bypass SMB altogether, but only back to one workstation or server.
