kyocera 5050 jamming when printing from multi bypass
  • ranjith@ast
    • Feb 2015
    • 5
    [Jamming] kyocera 5050 jamming when printing from multi bypass
    Hello
    I have an issue in kyocera 5050 machine while printing A3 print from multi bypass paper jam occuring and showing jam 21 code. A4 is working fine
    I already changed bypass unit, bypass paper path unit ,vertical feed unit, middle feed unit and bypass drive unit with belt.Anyone have suggections pls help me..
  • AlbertK
    • Jul 2014
    • 90
    Re: kyocera 5050 jamming when printing from multi bypass
    Hi, Does the machine actually register that there is A3 in the bypass ?
    The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
    • Max
      • Oct 2011
      • 569
      Make sure the bypass is set to auto detect or at least manually set it to A3, as side to side fences maybe registering different paper size.
      • ranjith@ast
        • Feb 2015
        • 5
        thanks for the reply, i solved the issue.problem was dirty rubber roller placed in duplex unit
