FS-C8525MFP changing incoming fax size?
  • captain
    • Mar 2015
    • 11
    On a FS-C8525 MFP when a fax is coming in the size of paper is asking for Statement size to complete the job. Is there a way to override the incoming fax to print on letter size instead of the requested Statement size?
  • kkendric
    • 301
    Re: FS-C8525MFP changing incoming fax size?
    Have you even checked what the default paper size and tray is for Fax?
    • captain
      • Mar 2015
      • 11
      The only option I have found that is relatively close to changing the default paper size for a fax is under System Menu > Fax > Reception > Reduce RX size. Is this option for changing the defaults for a received fax under a different option that I am just not seeing?
      • kkendric
        • 301
        The instructions can be found in the Fax instruction guide, Fax System U I believe.
