CS205 Memory allocation error ...not sure on what is means ..new to this product!!![emoji20]
KYOCERA CS205
Re: KYOCERA CS205
Did it give you a service code? To help I need some idea of how this came about. Have you added a fax card or done anything at all to the machine? Try to enter service mode by entering 10871087 on the key pad (you have to do this fast) when you get into service mode; enter in 906 on the keypad and hit the start button, hit the execute button, then the start button. The machine will tell you to power off and on. If this doesn't clear the issue. Reseat all the memory dimms.
An error code would help a lot.Comment
