FS-1016 scanner problem!
  • cmpelser
    • Jan 2008
    • 173
    Hi, on the fs-1016 the scanner is not allways working well???
    It keeps saying it's locked - press start.
    moves to the right and not to the left... So it does not go back to home position.
    Sometimes it will move to the left... I can't even get the thing to make 1 copy
    I have stripped and cleaned out everything... when I turned it on, it looked like it was fixed... then I tried to make a copy, and it did not work!!!
    PLEASE HELP ME.
  • bariskurt23
    • 16
    i see this problem fs1116 scanner motor not working replace scanner unit
    2G470010 UNIT OPTICAL MODULE
