After changing MK, Kyocera prints out only half a page
  • VanOverloop
    • Sep 2024
    [Misc] After changing MK, Kyocera prints out only half a page
    Hello,
    Does anyone has a clue what we might do wrong?
    Thanks,
    Tom
  • ss12
    • Jul 2008
    • 289
    Re: After changing MK, Kyocera prints out only half a page
    Have you run the dev setup,it runs for around 15 mins to add toner to the dev unit
    • VanOverloop
      Hello,
      Thanks for quick response. I should verify this tomorrow.
      Is this a main reason for this problem or might there be other little human errors that cause same problem?
      Thanks!
      Tom
      • ss12
        • Jul 2008
        • 289
        Originally posted by VanOverloop
        Hello,
        Thanks!
        Tom
        Because it's a mono-component machine it takes 15 mins to add enough toner to an acceptable level.a quick check of the mag roller should tell you if it's been done
        • VanOverloop
          Hello,
          Update: you were competely right! I asked my coleague to redo process (including 15 minutes process) and suddenly everything is okay except for 1 issue: now printer gives again message to change MK. Isn't there a kind of reset to solve this wrong message?
          Thanks!
          Tom
          • ss12
            • Jul 2008
            • 289
            Hello,
            Thanks!
            Tom
            Not sure about this model but if you go into service mode and see if there's a U251 reset
